Re: sickle mower
Posted by Steven f/AZ on August 24, 2008 at 09:54:06 from (24.156.15.203):
In Reply to: sickle mower posted by Tugb on August 24, 2008 at 06:49:01:
OK, in order to cut a sickle mower has knives that move back and forth through the guards - this cuts the grass somewhat like a scissors. A pitman type mower has a pulley with a pitman stick attached to it that moves the knife back and forth. A pitmanless type does away with this pulley and stick and is able to cut with the bar at more extreme angles. (too much angle with a pitman type mower and the stick breaks)
As far as raising and lowering the bar, you should be able to find one that will work with your touch control for that.
If you are planning on mowing a lawn every week or so, you don't want a sickle mower. Sickle mowers are for when the grass is at least a foot tall for you to cut it off, rake it up, and bale it. For lawn mowing, you'll want a Woods rotary mower...
What kind of look are you going for after mowing? How often do you plan to mow?
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
