Re: sickle mower
Posted by Tugb on August 24, 2008 at 10:21:11 from (199.227.104.226):
In Reply to: Re: sickle mower posted by Steven f/AZ on August 24, 2008 at 10:10:55:
thank you very much Steven! you probably just saved me some heart ache after i got it hooked up and tried to cut some 4" grass w/ the sickle! I guess that guy i saw was just using it wrong.
thanks again
Tug
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
