Re: Voltage regulator and steering wheel wheel in a 240 Util
Posted by boomer22 on August 24, 2008 at 14:30:21 from (199.120.77.167):
In Reply to: Voltage regulator and steering wheel wheel in a 240 Utility posted by veener79 on August 24, 2008 at 12:30:52:
Might need to heat it a bit, then let it cool, should loosen the rust build up in and around the shaft. Don't forget the PB Blaster or like lube to help out
This post was edited by boomer22 at 14:31:33 08/24/08.
