Re: WD-6 hydraulic system
Posted by KEB1 on August 24, 2008 at 15:42:22 from (63.227.46.223):
In Reply to: WD-6 hydraulic system posted by rberntson on August 24, 2008 at 12:58:44:
One off an MD will work, its the same engine. The diesel engines turn the pump (and magneto) in the opposite direction of the gas engines, so they're not interchangeable between gas & diesel.
My WD-6 came with an old caterpillar hydraulic pump mounted on the front of the chassis in the hole where a crank would go, & driven by a shaft directly off the crankshaft. Just about any hydraulic pump should work with this arrangement. Someone had to make up an adapter plate & the shaft, but it works just fine. I did acquire a pump that mounts on the magneto drive off of an MD, but haven't gotten around to changing it yet.
Keith
