Re: Voltage regulator and steering wheel wheel in a 240 Util
Posted by GA Dave on August 24, 2008 at 18:20:21 from (207.69.139.149):
In Reply to: Voltage regulator and steering wheel wheel in a 240 Utility posted by veener79 on August 24, 2008 at 12:30:52:
The voltage regulator is mounted on a bracket directly over the serial number plate on the bell housing. The steering wheel has two 1/4" NF tapped holes for a puller. Mine were too far gone to use so I destroyed the plastic or whatever using a three jaw puller. Hope you have better luck. David.........
