Re: IH 340 part
Posted by PaulW_NJ on August 24, 2008 at 19:51:47 from (72.76.239.55):
In Reply to: IH 340 part posted by doug rooney on August 24, 2008 at 14:37:30:
Call Hoober dot com"s toll free number in Intercourse, PA. They have a used parts locator and have found me discontinued parts used. Otherwise you may have to buy a used distributor to get the gear.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
