Re: Adding 3pt Hitch to 340u with Loader Hydraulic Plumbi...
Posted by BMD on August 25, 2008 at 07:28:41 from (65.254.172.6):
In Reply to: Re: Adding 3pt Hitch to 340u with Loader Hydraulic Plumbi... posted by TractormanNC on August 25, 2008 at 06:42:03:
I guess I need to get the info off the loader valves and see if I can find some documentation on them.
So I end up with 7 lines to two spool loader valve asm.I currently have 6.
1--------input from belly pump
2-3-4-5--outputs to loader cylinders
6--------return to tank
and after
7 -------POWER BEYOND to the added 3pt hitch valve.
Power Beyond port supplies Hyd power at pump pressure to additional valves is this correct?
thanks for the info...
