Re: Question's 350u steering wheel leak
Posted by Janicholson on August 25, 2008 at 07:40:27 from (199.17.6.122):
In Reply to: Question's 350u steering wheel leak posted by lester350u on August 24, 2008 at 15:28:10:
I was able to pry out the old seal from the top. I knew I had the correct replacement in hand, so I was not attempting to be careful other than to keep the surfaces from being marred up. It is easy once the wheel is off. Polish up the shaft where there may be rust on it , to keep from abrading the lip. I put a bit of hytran on the seal as I put it in to lube it. JimN
