Re: 300 wiring diagram
Posted by Janicholson on August 25, 2008 at 07:50:40 from (199.17.6.122):
In Reply to: 300 wiring diagram posted by Craig T on August 24, 2008 at 14:45:23:
A bad connection at the solenoid (on the big terminal that has the battery negative cable hooked to it coulod cause the starting current to flow in a direction that would allow the wire to melt. Two items The starter motor always looks like a direct short to ground. It draws hundreds of amps, and has near zero ohms. JimN
