You will need to pull the head too. You will need a sleeve puller to pull the sleeves. You probably will need a ridge reamer so the rings will clear the top of the sleeves. You probably need to check that block bore on the sleeve that broke. Probably wasn't tight enough in the block. Just remove the rod nuts and cap and you should be able to drive out the rod and piston. Use a piece of 2X2 oak and a big hammer. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
