Re: Farmall M Front Stearing Gear leaking?
Posted by Bob M on August 25, 2008 at 16:57:15 from (74.74.143.149):
In Reply to: Re: Farmall M Front Stearing Gear leaking? posted by Shoreman on August 25, 2008 at 14:04:37:
The "axle stem" ELD refers to is the "bolster pivot shaft" in the parts catalog. Matters not whether you've got a wide or narrow front - the bolster pivot shaft is the same for both.
Replacing the pivot shaft seal is not difficult. But a couple large and heavy parts must be removed to get at it. Also unless the seal surface on the pivot shaft is in good shape, oil will leak out of a new seal same as it did with the old one.
Consequently the quickest/cheapest fix is to simply pack the steering gearbox full with good quality wheel bearing or corn head grease. The grease will not run out thru a worn pivot shaft seal. And it will lube the worm and sector gear as well as gear oil.
