Re: farmall H bearing torque value low oil pressure
Posted by Nebraska kirk on August 25, 2008 at 20:39:23 from (98.19.43.14):
In Reply to: farmall H bearing torque value low oil pressure posted by Rich ORourke on August 25, 2008 at 19:46:43:
Main bearing torque: 75ft/lbs .002-.003 inch oil clearance
Rod bearing torque: 40ft/lbs .002-.003 inch oil clearance
