Re: what would you buy?
Posted by HemiMoparMan on August 26, 2008 at 06:25:00 from (97.97.6.26):
In Reply to: what would you buy? posted by Roger46 on August 25, 2008 at 10:13:53:
Here is the test results for the 706 and 756 from Nebraska Tractor tests.
Nebraska Tractor Test 858:
Engine: 263 gasoline
PTO (rated eng speed): 73.82 hp [55.0 kW]
PTO fuel use (rated): 12.86 hh/g [2.5 kWh/l]
Drawbar (max): 66.18 hp [49.4 kW]
Oil capacity: 9 qts
Nebraska Tractor Test 957:
Engine: 291 gas
PTO (rated eng speed): 76.56 hp [57.1 kW]
PTO fuel use (rated): 12.16 hh/g [2.4 kWh/l]
Drawbar (max): 65.67 hp [49.0 kW]
Oil capacity: 9 qts
Battery: 1 (gas/LPG)
Nebraska Tractor Test 955:
Engine: 310 diesel
PTO (rated eng speed): 76.09 hp [56.7 kW]
PTO fuel use (rated): 15.08 hh/g [3.0 kWh/l]
Drawbar (max): 67.46 hp [50.3 kW]
Oil capacity: 12 qts
Battery: 2 (diesel)
Sorry, I don't see the fuel savings in here. Do you?
And there is an extra battery required for the diesel, and an extra gallon of oil required too.
