Simple--- Connect all wires that were on both sides of the amp meter into one connection. Put one small bolt through all and tighten it up. Tape, or shring tube tha connection as it is a "HOT" wire electrically.
Gauges are available at the right size. Put the gauge in and connect the same side to ground as your battery is grounded. Then connect the other side to the ignition switch wire going to the coil (if distributor ignition. If magneto, a switch will be needed to turn the switch on and off from the light switch power wire. Some gauges draw so little that they can be left on all the time. then connect it up to the light power wire with no switch. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
