Re: B Farmall wont run with choke open
Posted by old on August 26, 2008 at 19:43:12 from (4.245.6.248):
In Reply to: B Farmall wont run with choke open posted by thumbanger on August 26, 2008 at 18:18:12:
Just had that problem on a tractor Sunday. You most likely have a fuel flow problem or a clogged carb. I would start by pulling the carb drain plug and make sure you have a good steady flow of gas from it. If you don't then work back to the tank to find where it stops. If you have a good flow then pull the main jet plug and spray carb cleaner into it with the drain plug out. Then put the plug back in ans spray it some more. Then drain the carb out and put the drain back in and give it a try. If it runs well then you probably have it licked if not you will probably need to rebuild the carb
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
