Re: using alcohol in yesterdays engines.
Posted by kossuth on August 27, 2008 at 03:23:40 from (214.3.140.16):
In Reply to: using alcohol in yesterdays engines. posted by jonnny2006 on August 26, 2008 at 21:00:00:
The only issue I would be concerned about is gaskets and such in the carb. This discussion has come up some and the major problem with running E85 in an older engine is that alcohol is that it is very corrosive to certain types of gaskets and rubber seals/lines. If your lines and gaskets are compatable then all is well if you turn up the fuel and timing.
