Re: B Farmall wont start
Posted by old on August 27, 2008 at 08:04:14 from (4.245.4.247):
In Reply to: B Farmall wont start posted by ELD on August 27, 2008 at 07:56:21:
Have you tried pulling the air tube off the carb and holding your hand over it and try to start the tractor?? If it tries to start then you have a clogged carb. Did it just one day die or have you done some work to it and got something wrong?? Is the firing order correct if you changed the cap its easy to goof that up
