Re: 1950 Farmall H hydraulic belly pump, I need HELP!
Posted by RustyFarmall on August 27, 2008 at 08:44:13 from (209.152.78.71):
In Reply to: Re: 1950 Farmall H hydraulic belly pump, I need HELP! posted by DickelDawg on August 27, 2008 at 08:26:55:
If you didn't get that actuating shaft back on just right, it will only sort of actuate the pump a little bit, and then it will slip over the cogs and do nothing. Made that mistake myself once. Pulled the lever, raised the wagon to dump the load, and then couldn't get it to go back down. Luckily I had some wrenches with me.
