The mag is, as I stated, not connected to anything but the mag Kill switch in the electrical box. (push pull, on off switch) That switch is a single terminal switch that grounds the wire attached to it when the switch is pushed in, and opens (allowing mag operation) when pulled out. No modifications are made to any part of the ignition Mag or grounding switch or the single wire running to it.
Assuming a three wire SI10 GM delco alternator.
The alternator should be connected as follows: a #10ga wire connects to the big "bolt on" terminal on the alternator. From there it is connected to the amp gauge, on the load side of the gauge (the side not attached to the Battery + side through the Starter Switch) Using a Fuse link saves burnt parts and fires. NAPA has them, (crimp on, not solder) JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
