Re: Farmall H - Replacing 5th Gear
Posted by TomH in PA on August 27, 2008 at 16:04:15 from (67.142.130.20):
In Reply to: Farmall H - Replacing 5th Gear posted by Ryan B. on August 27, 2008 at 07:20:25:
It sounds worse than it is to get into the transmission. Hardest part is handling the belly pump because it's so heavy and not much to hold onto.
Could be all you need are shims or a new pilot bearing rather than the gear itself.
