Re: B Farmall wont start
Posted by Andy Motteberg on August 27, 2008 at 16:53:34 from (4.143.218.31):
In Reply to: B Farmall wont start posted by ELD on August 27, 2008 at 07:56:21:
Make sure that the timing is correct and that the plug wires are in the correct order in the cap. Have you done a compression test in all the cylinders? How much do you have in each cylinder? Do you have a magneto or a distributor? If you have a magneto, are the rotor drive gears in the correct time?
Good luck!
