Re: B Farmall wont start
Posted by old on August 27, 2008 at 17:21:34 from (4.244.57.73):
In Reply to: Re: B Farmall wont start posted by ELD on August 27, 2008 at 08:51:40:
Wel first off double check which direction the rotor turns. Then get #1 up to TDC. Look where to rotor is and hook up the wires. It will either be correct or 180 out
