Re: IH 350 Utility Hydraulics
Posted by Janicholson on August 27, 2008 at 19:07:02 from (66.173.50.17):
In Reply to: IH 350 Utility Hydraulics posted by Darin in Nebraska on August 27, 2008 at 18:34:46:
The on board system consists of a pump mounted in front of the distributor driven by the gears at the front of the engine, and in turn driving the distributor. Steel lines run to the hydraulic reservoir and control components under the seat. The valving is on the right side of the seat, and can have several stacked valves. Usually two in front for remotes, and one in back for a fast hitch up down control. Hydraulic oil is directed through a priority valve in the seat reservoir through steel lines to the power steering. caseih.com has parts diagrams on line, just follow the search for parts topic. JimN
