Re: Hydro 84 Transmission Replacement
Posted by Allan In NE on August 28, 2008 at 04:47:54 from (148.78.243.26):
In Reply to: Re: Hydro 84 Transmission Replacement posted by chris4905 on August 27, 2008 at 10:27:36:
Can ya lug the engine down in reverse? I.E. Aside from the normal 50% gear reduction, does reverse seem "more or less" normal"?
What I'm getting at, is that the transmission uses the same components in both directions. Therefore, if one direction is okay, the unit has to be sound and there is just a hydraulic flow problem in the forward routing of the oil.
However, if both directions are really lame and "slippy", the chances for it being a fried pup go up quite a bit. Weak in both directions is when ya start keeping an eye on yer wallet. :>)
Allan
third party image
