How to check coil on Super H
Posted by VA Gasman on August 28, 2008 at 04:58:53 from (208.103.139.16):
I have a SH and have a problem starting it with starter when cold. If you roll start it kicks right off. Go to the field runs fine cut it off and starts right back up with starter once you have started. On the initial start up, it acts like it's been flooded even though I start it at 1/4 throttle and no choke. This started about 1/2 way thru hay season.
I ponder if it is the coil? I had some low spark issues earlier and replaced points condenser and plugs.
Puzzeled in VA
