Matthew: Your plow may be none of the plows you listed. The position of the plow lift on top blocks the view of back cross member between the beams. If that back cross member is diagnol flat bar, it will be a plow built at Canton IL Most Canton built plows had A, B, C, H or M in front of the number, and the letter indicated the tractor plow was intended for.
Then there are also Hamilton ON built plows and they all had model numbers that started C-xxx C in this case indicating Canada. Canadian built IH plows all have a perpendicular or square across back cross member. Given your location and the fact that all those years Canadian dollar was $0.75 or less USD, a lot of equipment, all makes got trucked to Michigan.
That is the only real difference between US and Canadian built plows, doesn't matter what size or configuration. US built plow has diagnol cross member, Canadian built has perpendicular cross member. The reason for the perpendicular cross members, they give an adjustable width frame. By configuration I mean trailer, fast hitch or 3 point hitch. This happened as a result of different plow cutting widths wanted in eastern Canada than in western Canada, one frame served all. A lot of those Canadian built plows got sold new in New England.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
