I had a Farmall M (same transmission as OS6)that would slip out of 4th gear unless you held it in. Gears were fine.
What I found was that not only was the detent notch on the shift fork worn, but the the hole in the transmission top cover where the spring loaded detent ball goes was egg shaped.
I got a good used shift fork and put a stronger spring in with the ball. To really do it right, I should have welded and re-drilled the egg shaped part of the detent ball hole in the top cover, but I didn't have access to a welder.
It was a bit harder to shift after that, but never slipped out of gear.
The part of your description where you said it slipped back 1/4" makes it sound to me like you have the same problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
