Posted by James Rumph on August 29, 2008 at 03:36:04 from (24.192.125.175):
In Reply to: Stuck Valves posted by S/C BOB on August 28, 2008 at 08:15:29:
Hate to say it but you need to pull the head and side cover. When the manifold is off check the mismatch on the ports use the gasket to see how bad "port match".
There isn't any push rods or rockers it's a flat head , this is a very simple job.
Pull the oil filter lid off , you will find a pipe plug there or a hole i forget. This hole is what feeds oil to the valve train, put air to it to make sure it blows thru. If it wont then start with brake clean and everything else tell you get it clear.
My father found a 54 cub that had been sitting in a barn for 30 years for real. Well the valves were stuck in it , i took them out and cleaned everthing . They stuck again because the oil passage was plugged.
The area ware the oil filter sits is under oil presure so this port feeds oil to the valve train under presure.
You can also try running some ATF in the oil 1 quart ,it will clean the inside of the motor real well and may unstick that valve.
I have run the motors with straight ATF no engine oil but didn't work them very hard , it cleans them out real nice. A friend of mine swares buy "Sea Foam" he adds one can to the oil and it cleans them out nice.
Anyway you look at it you have a bit of a job in front of you. Check that oil passage if you end up opening the motor, when its clear you will see the oil come out in the lifter galley.
Side note brake the head bolts free by hand not impact, i have read several accounts of guys brake them off. Also put sealent on all the head bolts when you put it back together , they all go into the water jackets. Retorque when hot !
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
