Thanks for the replies. I actually found a 5 foot section of 1 1/2 pipe in my basement. It still had the orange cap over the threads on both ends.
Unfortunately, it is all a moot point now. I went to drain teh oil, in preparation for starting it for the first time since I got it, and there was about a gallon of antifreeze in the oil pan.
I bought the tractor from a guy who rebuilt the engine last year. they fired it up, it was ticking loudly, they assumed a valve needed adjusted, and then he died. So, his son sold it to me. They couldn't have possibly known. Now, I don't know whether it has a crack in teh block, or the headgasket was not installed properly. The cylinder head has had a ton of work done to it, and every part looks brand new. The problem is, I got the oil pan off, and noticed that there is still red primer inside the block. So, they did not have the engine block dipped and magnafluxed.
So, we'll see... I am crossing every finger I have on this one.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
