Well, a dry sleeve will fit inside a machined bore in the engine block, so coolant never touches this sleeve. This is what the H, M, and Supers, etc.. have.
A wet sleeve, however, is in direct contact with coolant. I've never had one apart, but I read here all the time of o-rings going bad or failing due to improper installation. The o-ring is at the bottom of the sleeve where is contacts the bottom of the water jacket. I believe the top of the sleeve is sealed by the water jacket. The A, B, and Cs will all have this engine.
To repair you'll have to pull the sleeve. A lot of guys pull the oil pan first and look inside to isolate the leak. The bottom of the sleeves ought to be visible.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
