Re: M Carb Dumb Question Time II
Posted by Neb Super H on August 29, 2008 at 07:48:24 from (198.133.245.253):
In Reply to: M Carb Dumb Question Time II posted by Dan Bear Kelley on August 29, 2008 at 06:35:34:
I just had the same problem with my super H (it has an M carb). I found 2 problems:
The pin the float pivots on was too small and too tight and it would not let the float close all the way with floating pressure. (it would close when I pushed it)
The float was also hitting the inside or outside of the bowl in the carb and was getting stuck.
Fixed these two things and no problems.
