Re: M Carb Dumb Question Time II
Posted by Andy Motteberg on August 29, 2008 at 08:54:08 from (4.143.223.242):
In Reply to: M Carb Dumb Question Time II posted by Dan Bear Kelley on August 29, 2008 at 06:35:34:
third party image
Does it have a good flow of gasoline to the carburetor? Since you said before that the manifold was loose, did you replace the gaskets? Are the carb to manifold bolts tight? Both carbs will work.
