I have had this same problem as well. What i found was that the float was catching on the inside of the carb. I first took a dremmel tool and smoothed the area where the float what catching. (The inside of the carb has a cast surface which is very rough.) Then adjusted (bent) the float into place with a needle nose. BE CAREFUL on this step tho, it is very easy to bend, but most likely will need to be adjusted. Hope this helps. Good Luck!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
