Re: Farmall M Stuck oil ring
Posted by MN Rick on August 30, 2008 at 06:48:52 from (71.210.155.248):
In Reply to: Farmall M Stuck oil ring posted by Jim R on August 30, 2008 at 05:51:03:
You didnt elaborate on how much oil it is using, but a stuck oil ring is a good guess. Kind of a common problem for engines that sit awhile. If, in fact it is a stuck oil ring, there is no 100% sure cure that I am aware of. Over the years, I've had the best luck with...1.Giving them a good tune up. 2.Making sure they have a good thermostat so the engine runs right up to temp. 3. Changing oil and filter, replacing oil with a high detergent diesel oil. (15W40 Rotella) 4. Putting the tractor to work for a few hours.
