Re: Farmall M Stuck oil ring
Posted by billde on August 30, 2008 at 09:44:19 from (72.26.91.191):
In Reply to: Farmall M Stuck oil ring posted by Jim R on August 30, 2008 at 05:51:03:
Run Seafoam in the gas. When not in use pull the plugs and squirt ATF in the cylinders. Between the two you may loosen up the oil control rings.
