Re: Farmall M Stuck oil ring
Posted by El Toro on August 30, 2008 at 12:35:59 from (64.12.116.73):
In Reply to: Farmall M Stuck oil ring posted by Jim R on August 30, 2008 at 05:51:03:
You should take it out and work the snot out of it
and see if that helps. You may need to pull the pistons and do a rebuild if it doesn't improve. Hal
