6 Gallons 140 wt. - unless you live in the extreme north, then 90 wt. Use GL-1 grade; it will not cause old seals to start leaking.
There is a "full" plug on the left side of the tractor behind the clutch rod. You can fill gear case/trans case until it starts to come out that hole. but, it is still going to be about 6 gallons. Easy to do. Repeat every 10 years.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
