Re: farmall super h 1953 changing gear case oil
Posted by Red Mist on August 30, 2008 at 17:58:41 from (72.171.0.146):
In Reply to: farmall super h 1953 changing gear case oil posted by poorfarmall1 on August 30, 2008 at 17:02:54:
poorfarmall1 said: (quoted from post at 17:02:54 08/30/08) just picked up 5 gal 90/140. but think its gl-5 what is gl-1?
It is the old, original formula which was in vogue when these old tractors and their seals were made. mike
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
