Re: farmall super h 1953 changing gear case oil
Posted by NDS on August 30, 2008 at 18:34:39 from (205.188.116.73):
In Reply to: Re: farmall super h 1953 changing gear case oil posted by poorfarmall1 on August 30, 2008 at 17:02:54:
In my opinion GL 5 will be fine. As far as GL 5 being hard on seals, I have M that has had GL 5 or at least multi purpose gear lube in it for at least 40 years. The M sat in open front pole shed for about 30 years until I got it out and started running it about 5 years ago, pulled frame cover cleaned out transmissiom/dlfferential ( everything looked good inside) filled it with GL 5 and it is still up to full check plug and nothing has been added.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
