There are a lot of "maybe" answers to your questions unfortunately.
The weight limit depends on a number of things, like if its a home made conversion, or if its something like the unit made by Saginaw. How many cyilinders are on it? You may have to worry about weighting the front of the H depending on what you want to lift with it.
Most H's are non-live pto, but also non-live hydraulics unless a live pump has been added onto it. (Also, there was the option for an aftermarket hand clutch, which made the tractor behave like there was a live PTO)
If the H only has the belly mounted hydraulic pump, its not live. You would want to look for a pump mounted to the engine in front of the distributor, or driven off of the fan pulley.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
