Posted by Hugh MacKay on August 31, 2008 at 03:26:34 from (216.208.58.191):
In Reply to: 594 D posted by Curtis Wadkins on August 30, 2008 at 11:38:47:
Curtis: These older glow plug diesels like D-188 and D-282 can be annoying to bleed air from the system. Main problem is the added cranking while maintaining glow plug use.
After you replace fuel and it is always best to put in at least 5 gallons for that restart, bleed the filters which should get solid fuel close to pump. It should have a bleeder on top of each filter and this can be done by graviety, no cranking. Next loosen injector lines on 2 or more cylinders at the injector. Crank the engine, without glow plugs until fuel without bubbles comes out loosened lines. Retighten the injector lines and it should start.
If it doesn't start, I'd tow start it rather than bleed the batteries by prolonged cranking while using glow plugs. Find a vehicle able enough to pull the 504 in road gear, and no faster than road gear. in other words don't over rev the engine while tow starting. Tow starting a diesel is not like gas where a quick pop of the clutch works. Tow starting these is a matter of steady speed, with engine turning, glow plugs engaged, until tractor starts to fire. You can do this in 4th gear if tow vehicle is steady and heavy enough, main thing here is have the tow vehicle same speed as 504 would travel at selected gear and throttle setting.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
