Re: Aftermarket 3 pt. hitch Questions
Posted by Hugh MacKay on August 31, 2008 at 08:34:58 from (209.226.106.103):
In Reply to: Re: Aftermarket 3 pt. hitch Questions posted by riverbend on August 31, 2008 at 06:07:11:
Greg: Over the years, if I were rough enough on the clutch even the 1066 with no implements and no front end weight, front end would come off the ground. I've never had a tractor that wouldn't do that if you drop the clutch quick enough at much over half throttle, and no load on hitch.
I've also worked that tractor many hours with 8,000# on the 3 point hitch, at lower link hitch pin. I've sprayed thousands of acres with 656 and 200 Imperial gallon 3 point hitch sprayer, 300 with 100 gallon sprayer. Even my lowly 130 handles a 60 gallon sprayer quite handily with 200# of front end weight.
