Posted by Janicholson on August 31, 2008 at 17:02:06 from (66.173.50.158):
In Reply to: Re: M wiring Issue posted by Eppe Dad on August 29, 2008 at 19:07:30:
They are shown on the diagram (prior post) as 1 and 2 on the alternator. #2 goes to the big post on the alt. #1 goes to either a oilpressure activated closed on pressure switch, or a seperate switch that can be turned on to make it charge, and turned off when shutting down. The switch you have for the Mag is actually for a distributor type ignition. It is wired in the only way it can be, but it will work backwards. The correct switch will have only one terminal, and the switch body is grounded. It is ground when pushed in. The one you have is connected when out, and one side of it is now connected to ground, the other to the mag grounding terminal. Thus off is when out. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
