Re: Neg. vs. Pos. Ground
Posted by Clarkbug on August 31, 2008 at 17:23:56 from (209.23.9.136):
In Reply to: Neg. vs. Pos. Ground posted by Clarkbug on August 26, 2008 at 06:28:55:
For anyone that was keeping track, I finally got a chance today to play with the H.
It definitely just appears that the battery was switched around by the previous owner in an attempt to be helpful, and thinking that negative is always grounded.
I did try to jumper the terminals per the owners manual, but I honestly wasnt sure which was which on the generator or the voltage regulator, and none of my books helped me with that.
Im assuming on the generator that the terminal closest to the valve cover is the "a" terminal, and the one on the outside is the "f" terminal. I have the VR that is mounted to the generator, and there are three tabs. Two tabs on one side, one on the other. One of the ones on the side with two was connected directly to the generators "a" terminal, and the other was connected to the wiring harness.
There were sparks, but hopefully those werent bad sparks, but the kind I should see when re-polarizing a generator!
However, the H still runs quite rough... it starts right up, but doesnt idle very smoothly. The quest continues!
Thanks for all the help!
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
