Be sure to clean the axle and seal area, use a seal protector when installing(heavy plastic works for me) and slightly re-position the seal so it rides on an unworn axle surface. I left the seal about 1/16"-1/8" out from fully inserting it into the cap which puts the seal lip nearer the bearing on an unused axle surface. I put 3 seals on an SM-TA axle before using this tactic.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
