Re: Aftermarket 3 pt. hitch Questions
Posted by Bob Kerr on September 01, 2008 at 07:22:52 from (63.134.174.187):
In Reply to: Aftermarket 3 pt. hitch Questions posted by WI Dave on August 30, 2008 at 19:36:02:
The H will handle all your equipment fine. You may have to watch for the top link clearing the PTO shield when lowering some equip. I have a Saginaw hitch and extremly happy with it. I pick up large logs with the boom and drag them to the fire to top them out and then to the splitter to be cut up. Takes a green/wet log of 2'x 20' to get the front loose. If it does then I steer with the brakes and all is good. I do have to watch that the log doesn't hit a stump as there is a chance of flip over so I go slow in low gear and have my clutch foot ready. The H will walk circles around the 8N, but the 8N is easier to get on and off of, if you are going to do that kind of work.
