Re: IH MTA won't turn over
Posted by Buzzman72 on September 01, 2008 at 10:37:13 from (74.129.220.44):
In Reply to: IH MTA won't turn over posted by Greenleaf on September 01, 2008 at 10:29:56:
AFAIK, these tractors only had one ignition coil...and I don't know why the coil would keep the engine from cranking ["turning over"]. Are you saying it won't even turn over with the hand crank?
Sounds like you've got other problems.
