Re: IH MTA won't turn over
Posted by El Toro on September 01, 2008 at 10:48:09 from (205.188.116.73):
In Reply to: IH MTA won't turn over posted by Greenleaf on September 01, 2008 at 10:29:56:
Your coil has nothing to do with the cranking of the engine. The coil is used in the igniion for starting. For cranking you need a good battery, battery cables and a starter. If you have battery ignition your coil requires battery voltage in order for your engine to start. Hal
