Well the whole unit must come out and taken completely apart as the back cover is the last thing to come off . You will need to make a spring compressor to comperss the spring in the clutch pack after the clutch pack is out to remove the clutch drum . When removing the PTo unit from the tractor it is best done with a cherry picker so that you can handle it and one must tip the back end down as not to bang the pickup tube coming out or going back in . Then it would be wise to get the test fittings and a hyd. test gauge good for 600 lbs to test lock up pressure . AND THE MAIN THING HERE IS A BOOK.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
