H Carb Question
Posted by Minnesotan H on September 01, 2008 at 19:15:10 from (71.10.104.19):
Got out on the H over the weekend to do some cutting with the brush hog. I have been playing around with the carb since I put a new carb kit into it. Idle seems perfect but I'm getting a little sputter and "pop" when it's under a load at high throttle with the bush hog. Is this the mix screw (middle screw) or the load screw(bottom one)? What is the best way to tweek it under a load, trial and error or is there a better way?
